Is there any difference other than price tag between the MSI reference 980ti and the EVGA reference 980ti (just 2 examples). Everyone just seems to be selling the same thing with a different box and price
Current Rig
 CPU: Intel Pentium G3258 @4.0ghz MOBO: MSI Z87m-G45 RAM: Corsair Vengeance 8gb (2x4) CPU Cooler: Cooler Master Seidon 120v GPU: MSI R9 270x PSU: EVGA 500W 80+ Case: Corsair Air 240 (modded) SSD: Samsung 840 EVO 500gb HDD: Samsung 1tb Apple Hard Drive Mouse: Razer Naga 2014
https://linustechtips.com/topic/423084-reference-980tis/
The reference cards have bad price to performance.
Get a non reference.
but the reference cards look so badass xD
Current Rig
https://linustechtips.com/topic/423084-reference-980tis/#findComment-5681164
Would you rather have looks over performance, longer lifespan and quieter operation?
https://linustechtips.com/topic/423084-reference-980tis/#findComment-5681182
my country sell it with almsot 100dollar difference between zotax reference and msi reference.
no idea why.
CPU:  i7 4770k @ overclocked to 4.4ghz             GPU: Intel HD4600        SSD: Kingston V300 120GB (OS)                   Cooler:  Corsair H100i GTX
Case: Phanteks Enthoo Evolve (Black)                RAM: 2x4gb Corsair Dominator Platinium 2133mhz  HDD: 1TB Seagate                                            Mouse: Logitech G502
OS:     Windows 10                                                      PSU: Corsair RM850i 80+ Gold                                          Motherboard:  AsusZ97 Pro Gamer              Keyboard: Vortex Pok3r 3
https://linustechtips.com/topic/423084-reference-980tis/#findComment-5681187
but if im going to watercool it anyway?
https://linustechtips.com/topic/423084-reference-980tis/#findComment-5681191
Only real reason to go for a reference is if you want to vent the hot air out the back of the case, or lack quality airflow in your case. In which case a non-reference will be hurling warm air around inside the case.
Or if you want to use liquid cooling on the cards.
Shot through the heart and you're to blame, 30fps and i'll pirate your game - Bon Jovi
Take me down to the console city where the games are blurry and the frames are thirty - Guns N' Roses
Arguing with religious people is like explaining to your mother that online games can't be paused...
https://linustechtips.com/topic/423084-reference-980tis/#findComment-5681196
The airflow in my Air 240 isnt fantastic. i just have 2 slow speed fans in the front and one fan at the top so better ambient temps could be good. i just think the reference designs look amazing but also there is a lot of space restriciton on gpu width. i cant go for any wide cards because the power connectors push against my case window :/
Current Rig
https://linustechtips.com/topic/423084-reference-980tis/#findComment-5681255
nope, they're reference from nvidia. but just branded by that company.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/423084-reference-980tis/#findComment-5681259
Heyyo,
http://www.techpowerup.com/reviews/MSI/GTX_980_Ti_Gaming/18.html
GTA V, 2560x1440...
MSI reference GTX 980 Ti = $649.98 and gets 62.8 fps... so $10.35 per fps
MSI Gaming GTX 980 TI = $679.99 71.9fps... so $9.46 per fps
without overclock? The reference GTX 980 Ti has higher price to performance yes.
Now let's check overclocked:
http://www.techpowerup.com/reviews/MSI/GTX_980_Ti_Gaming/33.html
MSI Reference GTX 980 Ti = $649.98 and gets 102.6fps... so $6.34 per fps.
MSI Gaming GTX 980 Ti = $679.99 and gets 130.5fps... so $5.21 per fps.
Essentially... it depends how much money ya wanna throw at it. Reference cards do cost less sure, but depending on your goals with the card? The reference design isn't terrible. It's cheaper, has better custom liquid cooling compatibility and works better in smaller cases due to restricted airflow and the blower style pushing the hot air out the back of the case instead of non-reference coolers which vents the hot air into the case.
No there isn't any usually. EVGA's "superclocked" is the reference card with slightly higher clock speeds... that's usually the only difference between them. That? and depending what manufacturer? warranty can vary too depending where you live.
Heyyo,
My PC Build: https://pcpartpicker.com/b/sNPscf
My Android Phone: Exodus Android on my OnePlus One 64bit in Sandstone Black in a Ringke Fusion clear & slim protective case
https://linustechtips.com/topic/423084-reference-980tis/#findComment-5681279
maybe can head over pc part picker to check compatability.
https://linustechtips.com/topic/423084-reference-980tis/#findComment-5681289
Heyyo,
GTA V, 2560x1440...
the work of custom pcb? for the extra performance i mean.
https://linustechtips.com/topic/423084-reference-980tis/#findComment-5681298
Heyyo,
The custom PCB's usually add more power delivery which can result in higher overclocks yes. Of course, that only matters if you want to overclock.
The MSI Gaming GTX 980 Ti has different modes. Even the stock OC mode has decent performance yeilds if you don't feel like pushing the card too hard.
Another one to check? Gigabyte Gaming GTX 980 Ti. It's pretty much just as good tbh. See which card has a lower asking price between the two and you'd be happy.
As you can see here? The Gigabyte G1 Gaming GTX 980 Ti actually slightly beat the MSI Gaming overclock.
http://www.techpowerup.com/reviews/MSI/GTX_980_Ti_Gaming/34.html
It also, probably thanks to the third fan operates cooler.
Heyyo,
https://linustechtips.com/topic/423084-reference-980tis/#findComment-5681360
Heyyo,
so gigabyte g1 gaming kinda the best 980ti out there right now?
how about evga kingpin? heard about it broke some 3dmark record or something like that.
https://linustechtips.com/topic/423084-reference-980tis/#findComment-5681468
Heyyo,
http://www.kitguru.net/components/graphic-cards/anton-shilov/kngpn-and-evga-break-3dmark-records-with-four-geforce-gtx-980-at-2ghz/
That was with the EVGA GTX 980s EVGA K|NGP|N editions. Notice he's definitely not using the normal cooler lol as he's using a liquid cooling solution. :P
Also... the K|NGP|N Edition is damn expensive... it's not worth it unless you're trying to set records tbh.
http://www.evga.com/articles/00944/EVGA-GeForce-GTX-980-Ti-KINGPIN/
I can't even find that 3DMark result with the EVGA GTX 980 Ti K|NGP|N Edition... I'm sure it is possible for 2GHz on the core clock much like the GTX 980 Classifieds... but that's with liquid cooling and stuff lol.
Heyyo,
https://linustechtips.com/topic/423084-reference-980tis/#findComment-5681759
Heyyo,
All of the 980ti Kingpin records are only on 1x gpu's no one has made a 4 way sli 980ti Kingpin system yet (im sure well see alot though [ 980ti ran a freaking 29880 graphics score solo on firestrike normal]) also the clock speed reported by 3dmark was 1724 so that could be boosting into the 1900s.
Do not go for a 980ti kingpin unless you want serious watercooling or even LN2 cooling otherwise youre just straight overpaying for something that pretty much every other 980ti non reference can get close to. i personally have a 980 ti g1 gaming and love it, you might get some coil whine with them though, mine is pretty hard to hear and is usually drowned out by fans.
CPU i7 4770k (4.5ghz OC) | CPU Cooler Swiftech H220-x | GPU 980ti G1 Gaming (1562 mhz) | Mobo EVGA z87 Stinger | RAM 16gb Kingston HyperX Beast 1866mhz | PSU EVGA 850w B-2 | Storage Seagate 2tb hdd 7200rpm(main storage) & Samsung 840 EVO 250gb (boot drive) | Case Corsair 250D
https://linustechtips.com/topic/423084-reference-980tis/#findComment-5681937
will get after i get my hands on a acer xb280kh 1st. now only a 1080p 60hz monitor 980ti will be such a huge waste.
https://linustechtips.com/topic/423084-reference-980tis/#findComment-5682127
I'm going to be using 1440p 144hz with this card eventually
Current Rig
https://linustechtips.com/topic/423084-reference-980tis/#findComment-5688812
