High cpu temp running prime 95 blend test.
Solved by xTrekStorex,
prime95 is a synthetic benchmark and is designed to generate the maximum heat ouput of your CPU by calculating primenumbers on all threads available.
So it will get hotter than most games which use the CPU just as a manager for GPU and RAM communication.
There are some games that use a lot of CPU though like StarCraft2 (but only 2 cores) and Dota2.
You are running the stock heatsink right? That thing also isnt designed for 100% load over a longer time..
