Need Help Choosing Motherboard
Go to solution Solved by Loe,
Looks like I will go with the MSI H87m-g43 or the ASUS H87m-E (if I buy both wireless and sound card)
I am looking for a µATX motherboard that is socket 1150. I want to have an i7 4770, gigabyte 770 and dual channel 16gb ram. I also want an accessible pcie 1x slot for a wifi card.
EDIT :: Forgot to mention I have no interest in overclocking.
I have been looking at boards across 3 chipsets.
I initially was wanted the Asus B85m-g
Then the Msi H87m-g43
And finally the Msi Z87m-g43
I am just getting confused as to which chipset to get.
Another board I was looking at was the H87m-E.
What I want to know is what motherboard you think is best for my use case scenario.
CPU: i5 4430 PSU: XFX 550w Ram: 8gb Patriot Viper 1600mhz
Motherboard: MSI H87M-G43 Case: Fractal Design Define R4
SSD: 840 Evo 250gb, 512gb MX100 GPU: MSI GTX 980TI Gaming Cooler: Hyper 212 Evo
https://linustechtips.com/topic/42263-need-help-choosing-motherboard/
double post
please delete
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
is your chip unlocked?
It won't be, adding line I missed out.
The msi boards are the same except for the chipset. I would get the H87 as you won't overclock and the H87 is good feature wise board. The B85 chipset is aimed more for business or OEMs.
if you haven't already bought it, get the 4670k if you want to save money or the 4770k if you want to video edit
I was leaning more towards that one at the moment, the msi one. Currently in my saved part list on pcpartpicker.
I haven't, I won't be buying a k sku in any case however I do intend to do recording and editing.
if you don't mind me asking, why not? for a small amount of money you can get more power out of your cpu.
It costs more money, paranoia, looks like a lot of effort.
If you want a high quality micro ATX motherboard, you'll have to ditch the extra PCIe slot and use the on-board mPCIe WiFi controller (what more can you want from a board this size) - ASUS Maximus VI Impact Socket 1150. Definite recommend. As for a case, I've yet to find a decent micro ATX specific case. You could hit up a 350D, it's mATX downwards compatible.
Do you mean gene? That is their mini ITX board.
paranoia? :D
if you don't want to overclock you don't have to but if you ever want to or if you need more power you have that option
it's not difficult and the extra price is worth it. :)
paranoia? :D
If he doesn't want to overclock don't bager him to. Looking at other H87 boards that msi one looks to be the best one.
+1 this
the gene is absolutely amazing
+1 this
paranoia? :D
Yep, paranoia, everything will explode and I will die. I will consider it.
Discard what I said :D misread the initial post. Given that, switch up the Impact with the Gene basically, absolutely. I've got that current configuration, simply amazing.
I like the look of the gene, the extra cost of the board sounds justified if it does have wifi (does it?) and I won't need to invest in a soundcard.
Also will have the ability to run multi gpu setups if I wanted to.
Still a bit expensive but I shall think about it.
I understand where he is coming from, I just have very weird fews on the subject.
The Gene has an mPCIe Combo card which has WiFi built in without the need for a dedicated PCIe card. It came with my board, but I never used it .. hooked my shit up to ethernet instead. Yes, there are two PCIe slots that support multi GPU setups, although I have one in my board currently. I'd be fine with the mini ITX Impact to be honest  :lol: do think, tis amazing.
I really want to buy the gene purely because it makes no sense, £160 motherboard, £34 case (n200, already bought)
you can turn your computer into a wifi hotspot with that wifi card. just a fast favt you might not been aware of. :D
It looks like buying that motherboard is gonna save me at least £60, that justifies the cost in my eyes.
:lol: sounds like a justified reason to me.
Interesting, will look into it .. thanks  ^_^ maximizing those speeds to my smartphone.
Just get a cheaper mobo with cheap dedicated sound and wifi cards...
Onboard audio has nothing on even a cheap dedicated sound card.
