I honestly couldn't tell you. Apex (which I'd never heard of, by the way) seems to have quite an antiquated approach to specification sheets, providing only very few specs, not including CPU cooler clearance, and citing the ones they do provide in medieval units... Your best bet is just to take a tape measure and find out for yourself how big the gap between the top of the CPU and the nearest edge of the side panel is.
If you can't be arsed to do that though, just pick up a good low-profile cooler like a Be Quiet! Dark Rock TF or a Phanteks PH-TC14CS, and you ought to be golden...
Main Rig "Melanie" (click!) -- AMD Ryzen7 1800X • Gigabyte Aorus X370-Gaming 5 • 3x G.SKILL TridentZ 3200 8GB • Gigabyte GTX 970 G1 Gaming • Corsair RM750x • Phanteks Enthoo Pro --
HTPC "Keira" -- AMD Sempron 2650 • MSI AM1I • 2x Kingston HyperX Fury DDR3 1866 8GB • ASUS ENGTX 560Ti • Corsair SF450 • Phanteks Enthoo EVOLV Shift --
Laptop "Abbey" -- AMD E-350 • HP 646982-001 • 1x Samsung DDR3 1333 4GB • AMD Radeon HD 6310 • HP MU06 Notebook Battery • HP 635 case --
I have an amd fx 8320 cpu and that stock fan is shit. Is there a better cooler I can buy that fits in this case? (APEX TX-381-C Black Steel Micro ATX Tower Computer Case USB/Audio/Fan)
My board is microatx.
I am only asking because i dont think a 212 would fit.
a 212 prolly won't fit, get a low profile cooler from CM, phanteks, be quiet, noctua or thermalright
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103177&cm_re=cooler_master_geminii_m4-_-35-103-177-_-Product
http://www.newegg.com/Product/Product.aspx?Item=9SIA68V2TR2312&cm_re=be_quiet_lp-_-9SIA68V2TR2312-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16835709039&cm_re=phanteks_cooler-_-35-709-039-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16835709016
http://www.newegg.com/Product/Product.aspx?Item=9SIA4S82VX7230&cm_re=thermalright-_-9SIA4S82VX7230-_-Product
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
Where are you shopping/located? Budget?
