Building my PC
Go to solution Solved by grayblizzard,
Good day to ya all.
So, since my old rig just broke, I would like to take that as a sign to build me a new one.
This is where you guys come in ...
Would you mind checking if there are any bottelnecks etc. in this setup ?
I looked it through myself like 10 times, but since I am not that well suited with knowledge in this kind of environment, I would really appreciate your help.
https://www.mindfactory.de/shopping_cart.php/basket_action/load_basket_extern/id/3c31b92219706f760b9f66f10eb0f558675dc04d30945d5c20f
You may want to change the .de to the domain of your country, but for the link I didnt do it because I am not quiet sure if it would work then.
So, many thanks in beforehand,
SomeKiddie
just colormatch the build and you will be good i think
Good day to ya all.
SomeKiddie
Current PC broken, saving up atm.
Reason for saving up ->
https://linustechtips.com/topic/422467-building-my-pc/
Good day to ya all.
SomeKiddie
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/422467-building-my-pc/#findComment-5673173
Save yourself some cash and go with an i5, if the system is for gaming/ light productivity. also the motherboard should come with sata cables...
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/422467-building-my-pc/#findComment-5673233
It does, but in tjis version there are only 2 included, wich is not enough to use one HDD, an SSD and drive for CDs
https://linustechtips.com/topic/422467-building-my-pc/#findComment-5673256
Ahh, my bad...
https://linustechtips.com/topic/422467-building-my-pc/#findComment-5673277
Ahh, my bad...
Happens, dont sweat it.
Also, i would like this rig to be at least semi-future proof and I might also do some rendering/modelling stuff, so I assumed the i7 would be the better choice.
https://linustechtips.com/topic/422467-building-my-pc/#findComment-5673298
In that case go for it... I too was not sure what I would use my pc other than gaming, so I kept my options open by getting an i7.
In cases where people could nearly afford a much better gpu, then it would be better to cut down the cpu, and get a better gpu, but since you already have the top of the line, it should be fine.
https://linustechtips.com/topic/422467-building-my-pc/#findComment-5673332
Nearly exactly my thoughts.
But I am not quite sure if you mean the GPU is top off the line (wich in my opinion it isnt, but man, I dont have that much money :3)
https://linustechtips.com/topic/422467-building-my-pc/#findComment-5673356
You could get the 980 ti, or fury x, but I think thats a larger amount of money than you would get from going down to an i5...
https://linustechtips.com/topic/422467-building-my-pc/#findComment-5673597
