Sure.
https://linustechtips.com/topic/422010-please-help/#findComment-5667631
what kind of question is this?
1.) Topic should contain the problem - not "Please help"
2.) Search for your problem before you create your own thread.
3.) Why wouldn't you be able to have that?
:huh:
Bitfenix Phenom M White | ASUS RoG Maximus VIII Gene | Intel i7 6700K @4.6GHz | HyperX Savage 2800MHz CL14 DDR4 16GB | EVGA GTX1080 SC | Intel 750 Series PCIe SSD 400GB | EVGA SuperNova G2 550W | Windows 10 Professional x64 | Logitech G900, Corsair K70 RGB MXbrown O-ringed, BeyerDynamic DT880 (600 Ω) on Fiio E10K & Samson Meteor | Dell U2715H 27", Samsung SyncMaster P2450H 24", Samsung SyncMaster 931BF 19" | DIY Ambilight
https://linustechtips.com/topic/422010-please-help/#findComment-5667650
Go with a nvidia instead  :D but yeah it will work.
in my old rig it came stock with a i7 950 and some random amd gpu
CPU: I7 4790k  CPU Cooler: NH-D15 GPUMSI 970 4gb   Motherboard: z97 Gaming 5 PSU: Corsair hx850   Ram: Corsair Vengeance 8 gb  SSD: Samsung 850 Evo  Case: Air 540
https://linustechtips.com/topic/422010-please-help/#findComment-5667712
