Hello,
My brother has my old Lenovo G570 Laptop which had windows 7 pre-installed. He has downloaded lots of games when i told him not to because it doesnt have much space, so when Windows 10 came out we gave it the upgrade but it was basicly full i was trying to factory reset it but couldnt and accidently formated it and couldnt get it back to win 7. Now that i was able to install win 10 on it i cant get the drivers for the wi-fi. The warranty as expired and wanted to know if someone could help me in finding out which drivers i should download i have downloaded most of them, but most of the network drivers wont let me install them.
Heres the link for the drivers: http://support.lenovo.com/us/en/products/laptops-and-netbooks/lenovo-g-series-laptops/lenovo-g570-notebook?TabName=Downloads
https://linustechtips.com/topic/421909-need-help-about-drivers/
Hello,
give me the device manager hardware ID
If you need remote help fixing something on your computer
I can help over Teamviewer if you wish
just msg me on my profile
https://linustechtips.com/topic/421909-need-help-about-drivers/#findComment-5666391
Which ones have you tried?
https://linustechtips.com/topic/421909-need-help-about-drivers/#findComment-5666398
i have tried Networking: Wirless Lan
Win 7
Intel Wireless WiFi Link Driver
Wireless Lan Driver
Win 8
Intel Wirelss LAN Driver
Wireless LAN Driver (BCM, Atheros, Realtek)
and how do i get the Device Manager ID?
Press the key combination [Windows-Logo]+[R] and type the following command:
devmgmt.msc  and then confirm by pressing [Enter
then go under missing drivers or networking adapters..and click properties
https://linustechtips.com/topic/421909-need-help-about-drivers/#findComment-5666433
If you can install the Ethernet drivers, connect an Ethernet cable to the laptop, Windows 10 might be able to grab the WiFi drivers for you.
https://linustechtips.com/topic/421909-need-help-about-drivers/#findComment-5666435
i think i fixed it :) i was able to update the drive via the device manager! :)
https://linustechtips.com/topic/421909-need-help-about-drivers/#findComment-5666454
