first custom loop developed a leak need help
Go to solution Solved by jzwill7190,
thanks every one for the swift answers. its not a green o ring  i
You sure you didn't cross thread that fitting? Looks a bit crooked to me...
I'd drain into a clean bucket (you can re-use the liquid), and try and re-do that fitting.
yeah thats what i was thinking. i didn't really implement a good drainage system so its kind of a pain to drain. thanks for the advice .
Gaming/Folding rig: Coolermaster CM 690 II Advanced White | MSI Z77A-G43 | Intel Core i7 3770k @ 4.4GHz | 10GB G.Skill RAM | Nvidia GeForce GTX 780 | Samsung 840 Pro 128GB | Seagate 2TB | Seagate 2TB | WD Blue 640GB | Cogage Arrow (Passive) | Thermaltake Toughpower XT 675w | Windows 10 Pro
Photography
im a liquid cooling noob and my loop developed a slight leak where a fitting connects to the inlet. How can i fix this? can i fix this with out draining my loop? any help would be greatly appreciated.
-PIC-
Welcome to the Forums!
Looks fine to be unless that's not a green o-ring, but make sure it's properly torqued down and tightly secured.
I wouldn't have thought head pressure would be that much to cause a slow leak over a month..
In that case then try and torque it so it's only slightly more than hand tight, don't want to crack the plastic or anything so be gentle with it.
Photography
i don't think so, i'm not sure what happend. this loop was running for a month with no problems.
The only way of really checking is to take off the fitting and see if the threads and o-ring are in good condition, I would replace the o-ring just incase and see if that fixes it with a leak test.
thanks  i will probably try that.
Looks good to me :) The only thing you really need to make sure of is that the reservoir is above the pump, but you don't need to since it's a res/pump top combo.
Photography
