can i use software to control the fans on my msi gaming 5 and if so whats the best one to use
Speedfan would be your best bet. I personally don't like it, the interface is horrible and it's hard to understand.
Make sure the fan headers are PWM as well.
Another option is an internal fan controller with additional software, but that solution isn't for everyone.
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
https://linustechtips.com/topic/421379-software-fan-controller/#findComment-5660303
You have only two options for software. MSI Command Center and SpeedFan. Command Center is alright if you are new to all this. Speedfan requires more playing around with settings, googleing guides and reading overall.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/421379-software-fan-controller/#findComment-5668396
