need help with optical drive
Solved by Knaj,
Optical drives can have many different types, Blue Ray, regular DVD, DVD burners, and Blue Ray burners.
If you plan to do nothing with blue-ray, then just a normal DVD and DVD burner will do just fine ![]()
PopsicleHustler ·
Posted in Audio1 -
4
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases8 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
play_circle_filled
Latest From ShortCircuit:
