help with a cheap launchpad
Go to solution Solved by LittleCarrot,
It is a MIDI Controller
I have been wanting a launchpad for a while but then i looked an saw how much that where. (if i am right launchpad is a brand name). If it is a brand name what would it be called. any way it would be nice if you could show me sum cheaper ones.
CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
https://linustechtips.com/topic/420501-help-with-a-cheap-launchpad/
Oh thanks what are some you would recommend
I am not really informed in this area. But are you looking to do, and what is your budget?
I would like to get into some EMD and i would like it under $100 because you can get a launchpad at that price
You Know You Can get a Launchpad at $100?
I know that so that is why i would like to get one under $100 usd
Found this: http://www.amazon.com/Behringer-CMD-TOUCH-TC64-Controller/dp/B00SWDKN2W/ref=sr_1_6?ie=UTF8&qid=1438401841&sr=8-6&keywords=LaunchPad+Mini
In the End, the Launchpad will be the best since it has more community support.
"In the middle of every difficulty lies opportunity."
- Albert Einstein
I think i am done with changing my pics i think.
I may just go and get a Novation Launchpad but i will look a little more but thanks for the help
