The title says it all what is better for me to use a full cover block or a universal with passive heatsinks ... I am leaning more towards full cover atm even though a full cover is ALOT more expensive and i would need a new one if i ever upgraded adding on even more cost over the long run but if the card is going to take damage from using passives on the mosfets i dont want to go anywhere near it. Also would 2 cards in crossfire with a universal cause some problems for the passive heatsinks?
My pc is used for some hardcore 3D moddelling and Hi rez gaming with 3 monitors atm possibly max eyefinity will let me go to soon so the GPU can get VERY hot at times GPU will either be another 7950 or 2 7970's. does GPU make a difference?
this is my work computer so its the best i can get sadly cant afford ares 2 just to rip it appart to include in my loop... that would be blasphemy anyway
thanks in adavnce
https://linustechtips.com/topic/4203-gpu-blocks-full-cover-vs-universal-help/
if the gpu's get very hot, use the full ocver block. full cover also cools the vram and the power delivery ACTIVE. passive heatsinks work, but they do their job barely. even with a sidepanel intake (unless its a delta fan :P).
full cover blocks look better, and are more optimized for overclocking. if you dont care about the looks and only want a cool gpu with no extra kooling, go for universal.
"People assume that time is a strict progression of cause to effect. But actually from a non-linear, non-subjective viewpoint, it's more like a big ball of wibbly wobbly timey wimey stuff."
Dont understimate my skillsz, you might look foolish.
I have universal blocks on my two 6870's and from experience I can say whenever possible, go full block. You get the cooling on the vrm and ram chips as well. I had to buy a custom cooler for mine and additional fans and such which all in, cost almost as much as a full block. Also, with two GPUs and hooking them up, universal are very difficult. Having full blocks you can usually use SLI/Crossfire connector kits which make it a lot nicer and easier...
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
With high end video cards it's much better to get a full block.
Also like Whaler already mentioned going Crossfire with a universal block is not fun.
My Rig:
Case: NZXT H210 CPU: AMD Ryzen 7 3700x  Motherboard:  MSI B450 AM4 Motherboard  Memory: GeIL EVO POTENZA 16GB Video Card: MSI RX480 Power Supply: Corsair TX 750w Storage: Samsung 840 120GB And a 500GB WD BLUE Monitor: Acer S231HLbid 23" and an old Dell Mouse: RAZER DeathAdder 3.5G Keyboard: Ducky DK9008G2 PRO MX Cherry Blue
