EDIT:
1080p = 1080p, you GPU doesn't care if it's a small display, a huge TV or a projector, it just renders pixels ^^
AMD FX8320 @3.5ghz |  Gigabyte 990FXA-UD3  |  Corsair Vengeance 8gb 1600mhz  |  Hyper 412s  |  Gigabyte windforceR9 290  |  BeQuiet! 630w  |  Asus Xonar DGX  |  CoolerMast HAF 912+  |  Samsung 840 120gb
2 WD red 1tb RAID0  |  WD green 2tb(external, backup)  |  Asus VG278He  |  LG Flatron E2240  |  CMstorm Quickfire TK MXbrown  |  Sharkoon Fireglider  |  Audio Technica ATH700X
#KILLEDMYWIFE
https://linustechtips.com/topic/41966-1080p-fps-difference/#findComment-545601
no its just a bigger screen it does not require more power just because its bigger you will not see an FPS drop.
Pretty much^
You might require more 'power'/electricity to run the display though :P
https://linustechtips.com/topic/41966-1080p-fps-difference/#findComment-545607
