Cheap Hardline Water Cooling Loop
Go to solution Solved by W-L,
Just my cpu, im not looking for "cheap" just as low as possible like under $250
For that price point it would be hard to achieve something like that for hardline watercooling a kit from EKWB or XSPC could fit within that budget but not much more:
https://shop.ekwb.com/kits
I was thinking about doing a hardline water cooling loop and was not sure what parts to get, I have a few ideas but am not entirely sure. What would you guys recommend i buy? I am looking to spend as little as possible and would appreciate your feedback.
CPU: Intel i5 4690k @4.3GHZ COOLER: Arctic Freezer Pro 7 Rev 2  MOBO: Asus Z97-E RAM: Kingston Hyper X Black 2x4GB GPU: Soon to be EVGA 1070! Case: Fractal Define S Storage:PNY 240GB SSD, 500GB Seagate Barracuda PSU: Corsair RM650x
https://linustechtips.com/topic/419657-cheap-hardline-water-cooling-loop/
Custom watercooling isn't what you call cheap but in terms of components for hardline you will need tools to bend hardline, silcione bending mandrel, heat gun and bending guides if you want to have very even and consistent bends.
What do you plan on cooling? Just cpu, or gpu also. What is your budget, what is "cheap"?
Water cooling is usually NOT cheap.... Especially not custom loops
CPU: Intel Core i7 8700k CPU Cooler: Corsair Hydro Series H100i Mobo:  Memory: G.Skill Ripjaws X 32GB 2133 Storage #1: 1TB 850 EVO SSD Storage #2: Western Digital Black 2TB Storage #3: Western Digital Green 4TB GPU: Gigabyte 980 Ti G1 Case: Mastercase5 PSU: EVGA 750 W G2 80+Gold Keyboard: Corsair K70 RGB Cherry MX Brown Mouse: Razer Deathadder Elite Monitor: LG 34UM94 Headset: Bose
Phone: Samsung Galaxy S9
