What kind of dollars are you using?
Rest of specs?
Moving to Cases and Power Supplies.
https://linustechtips.com/topic/419642-what-case/#findComment-5639832
Enthoo Pro if your willing to have a full tower
PSU shroud, drive bays, air flow, plenty of air flow and included fans
CPU: Intel i5-2400 Mobo: ASUS Maximus IV Gene-Z RAM: 8GB G.Skill DDR3 1333MHz GPU: Sapphire R9 280x Tri-X Case Corsair Obsidian Series 350D PSU: EVGA 500w 80+ Certified
https://linustechtips.com/topic/419642-what-case/#findComment-5639851
america i5 4690k corsair cx 750 msi z97 mobo
What's the name of the motherboard?
https://linustechtips.com/topic/419642-what-case/#findComment-5639856
would it support push pull wix kraken x61
No, but I don't think you have to go push-pull.
If you really want to though, I suggest the Enthoo Luxe, but look into the exact measurements of your fans/rad and space available in the luxe
https://linustechtips.com/topic/419642-what-case/#findComment-5640069
https://linustechtips.com/topic/419642-what-case/#findComment-5640751
