I just updated to windows 10 and now Cinebech thinks my R9 280 is a HD 7900 series (Probably a HD 7950)
Is this a bad thing? I know that a R9 280 is a rebadged HD 7950.
I have 280 and says same for me
Join da discord
(Intel Core i5 4590 - XFX R9 280 - ASUS z97-A USB 3.1 - EVGA SuperNOVA 750B - 16GB EVGA DDR3-EDITION - NZXT H440 -
WD BLACK 1TB - OZC ARC 100 240gb)
#locked(ง ͠° ͟ل͜ ͡°)ง
https://linustechtips.com/topic/419624-cinebech-wrong-again/#findComment-5639546
And a 280 is a rebadged 7950. So it is technically a 7950. Why does it matter what it is called?
Why do people put Chev badges on their Holdens.
I doesn't make The car any different other than the name.
Anyway MY card is a R9 280 and it annoys me that it is wrong.
https://linustechtips.com/topic/419624-cinebech-wrong-again/#findComment-5639557
Look at the bright side, your '7950' is outperforming a 280 :P
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/419624-cinebech-wrong-again/#findComment-5639573
It's basically what you just said. The bios are kinda the same I think.
NEVER GIVE UP. NEVER STOP LEARNING. DONT LET THE PAST HURT YOU. YOU CAN DOOOOO IT
https://linustechtips.com/topic/419624-cinebech-wrong-again/#findComment-5639590
Is that the latest Catalyst 15.7.1?
If it's bother you so much, just edit the inf file yourself and change the name string to "AMD Radeon GTX Over 9000x Ti Nvidia".
https://linustechtips.com/topic/419624-cinebech-wrong-again/#findComment-5640153
