HI
This is going to be my first build and need help to check if the parts are compatible, I think they are but not sure. Here is the link: http://pcpartpicker.com/user/MARGARIN/saved/V3WLrH . If i should change some parts, tell me. But dont want the build to be more expensive. The parts have to be Black/Red
https://linustechtips.com/topic/417588-need-help-for-first-build-1300/
HI
why do you have a 750watt psu with a 392watt system.
HI
What do you want to do with it? For gaming an i5 is plenty. If you change the cpu to an i5 you have enough money to buy a 980 :)
System: CPU - I5-6500 Motherboard - Asus B150M-A RAM - Crucial ballistix sport 2x4GB DDR4 @2400MHz GPU - RX 480 PSU - Seasonic S12II 520W Case - Aerocool Aero-800 HDD - Seagate 1TB SSD - PNY CS1311 120GB Monitor - AOC G2260VWQ6
which CPU do you recommend me?
recommendmm
recommend
Either the 4690k, or the 2500k
HI
They will work fine. Without removing the 4790k (which really isnt needed but is kinda nice to say you have so I left for you), these are the very small changes I would make. I'm sorry I made it cost 6 more dollars, but you could change psu/mobo to fix that.
Also if you don't plan on using an optical drive buy a Fractal Design S instead of the R5 for about 20 dollars cheaper.
Adding the ssd that I did will massively insanely improve your daily use of the pc.
http://pcpartpicker.com/p/CPGMHx
Right, well if you are ok with dumping the 4790k (which you really don't need). I'd recommend this build:
http://pcpartpicker.com/p/d8CcsY
NOTE: The difference between the 390 and 390x isn't worth 100 dollars to me but idk if 4690k and 4790k is better imho. I would actually if it were me keep the 390 and the 4690k and just pocket the 100 dollars for anything else you might want (storage/sound/wifi/peripherals)
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor ($242.99 @ SuperBiiz)
CPU Cooler: be quiet! PURE ROCK 51.4 CFM Sleeve Bearing CPU Cooler ($26.99 @ NCIX US)
Motherboard: ASRock H97 PERFORMANCE ATX LGA1150 Motherboard ($79.99 @ Newegg)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Memory ($47.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($69.88 @ OutletPC)
Video Card: EVGA GeForce GTX 980 Ti 6GB ACX 2.0+ Video Card ($649.99 @ Amazon)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case ($99.99 @ Micro Center)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($79.99 @ NCIX US)
Total: $1297.81
Generated by PCPartPicker 2015-07-28 19:20 EDT-0400
If you wanna add an SSD do so, I'd get a 120gb for now just for the OS and small games that don't use more then like 30gbs
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
which CPU do you recommend me? mostly gone be gaming on it.
recommendmm
recommend
if youre only gaming get the i5 4690k (it´s a beast). Only go i7 if you are going to be livestreaming/editing. And with the money saved you can buy an ssd!
Or use my link and get one anyways.
Total: $1297.81
That is a super lolzy build. I mean it will work well, but lol. That's gross.
isn't the 2500k very old?
is the 390 better or worse then the 970?
Care to explain how? The only possible thing wrong with it is not having an SSD but that's a luxury not a must.
yeah the 2500k is pretty old but still very good. It has great overclock capabilites and is certainly worth the price (if you can still find one lol)
About the same. It's worth getting the 390 for the 15 dollars you save for sure.
A luxury that actually makes more of a daily difference than even a 390x vs 980ti at all but 4k. It really is day and night. No but I wasn't talking about that. The build is completely functional, but hilariously out of balance. Why not a Design S?
The build,is out of balance? How so? The build is perfectly balanced. I find the Design S to be ugly. The NZXT h440 is better in my eyes in every way. You almost see no cables with it, cable management is easy to do, the PSU basement makes a worlds difference in looks, I could,go on but it's just a much better case in terms of.. Well eveything.
As for the SSD my old Seagate drive boots my pc up in around a minute and is snappy. The 980Ti makes a night and day difference easily,over a 390 or 970. Don't sacrifice raw performance for some faster boot times or load times. It's not worth it and can easily be added later, a GTX 980Ti would be a lot more expensive to add later over a 970
Not to be snobby here, but it is rather implicit that you havent used a SSD desktop computer. It makes all the difference, and the 390 and 970 are more than good enough for 1080p.
Also why bother with a 1231 when a 4690k is cheaper? It comes at a higher base clock and if you are going to go lax on the cpu/mobo you might as well dump HT as well which isn't anywhere close to a performance boost in gaming or light use. (or a 4690 or any other i5 really)
I would argue about the h440 more, but it's all aesthetic anyways so no real point.
Also good spot on the PSU. I just kinda shrugged at the one listed and well didn't care. That is a good save of 40 dollars.
The op originally had a 4790k, the 1231 is Kindda like a mixture of a 4690k and 4790k. It's got around the same core clock of a i5 but it's hyper threaded like the i7. A SSD is not needed, it's a luxury not a must and quite frankly can be added later. Don't sacrifice FPS because you can't have a game booted up in 30 seconds or your PC boot up in 30 seconds.
But hyper-threading has little to no benefit to almost everyone (esp considering it makes zero difference in gaming), and its slower than the 4690k.
Don't sacrifice fps you can't see for tangible benefits that add up to time in rapid massive succession and that help you 100% of the time instead of just when gaming...
Again from our conversations, it's quite clear we have some amusing ideological differences...
As this is getting no where yeah let's just stop. The reason I choose it is because games are gonna start and are starting to use the extra threads like they did the extra cores on CPUs like the fx8'or 5820k
if you want to learn how to overclock the cpu and gpu, read my guides; links are in my forum signature
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($228.99 @ NCIX US)
CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler  ($64.05 @ Amazon)
Motherboard: Asus Z97-E ATX LGA1150 Motherboard  ($111.98 @ Newegg)
Memory: Kingston HyperX Fury Blue 8GB (2 x 4GB) DDR3-1333 Memory  ($41.99 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive  ($71.49 @ OutletPC)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($71.89 @ OutletPC)
Video Card: Gigabyte GeForce GTX 980 4GB WINDFORCE Video Card  ($499.99 @ NCIX US)
Case: Corsair 200R ATX Mid Tower Case  ($59.99 @ Micro Center)
Power Supply: EVGA SuperNOVA GS 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($76.99 @ NCIX US)
Total: $1227.36
Generated by PCPartPicker 2015-07-28 22:52 EDT-0400
BigDay
HI
$1156, SLI ready (GTX 970 G1).  The R9 390 is a very real option, either one will net you enjoyable gaming experiences.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.99 @ SuperBiiz)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.50 @ Newegg)
Motherboard: MSI Z97A GAMING 6 ATX LGA1150 Motherboard  ($131.98 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory  ($44.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($97.95 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($48.89 @ OutletPC)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card  ($358.89 @ Amazon)
Case: NZXT H440 (Black/Red) ATX Mid Tower Case  ($109.99 @ Newegg)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($79.99 @ NCIX US)  <<Enough power for two 970s, but not two R9 390s
Total: $1127.17
Generated by PCPartPicker 2015-07-28 23:06 EDT-0400
