Hello PC enthusiast community,
     Hey guys i hope you are having a better day today then i am, this has been going on for the past 2 weeks now and i can't seem to figure out why my GPU is throttling itself back. I'm getting massive core spikes every 3-5 seconds and it is unplayable. I started noticing the problem when i was getting heavy fps drops, so i turned on afterburner and noticed that my GPU was reaching temps up to 105 deg Celsius. which is really high. So i RMA my GPU (they gave me brand new GPU ) and put it in there and still the problem persists. The thing is i don't have extra parts to swap out to test what the problem is. I knew enough that i needed to find out if the problem is hardware or software so i re-installed OS with the CD, problem is still there. Its not the power supply i borrowed my brothers CX 600 , problem still there. im getting dips down to 40's when i should be getting 90-120 fps on low settings. At this point i don't know what to do and it can be very frustrating. The only idea i have is that the GPU fried my motherboard chip set when it got that hot? Any suggestions or input would be greatly appreciated, and thank you in advanced.
        Your fellow PC enthusiast, MyCampGround
PC build:
Wind 8.1 64bit
MSI A78M-E35
AMD athlon x4 760k
R7 260x 2GB OC
Crusial Ballistic Sport 1x8 ddr3 1600
West Digital Blue 1tb 7200rpm
corsair cx430
https://linustechtips.com/topic/417446-how-to-diagnose-the-problem/
Your CPU is probably bottlenecking the GPU, which, itself, isn't all too great. Also, that PSU seems kinda whimpy, imp
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
That only happens in CPU intensive games, but it it was bottlenecked, it wouldnt be 100% usage and much lower temps.
PC build:
Wind 8.1 64bit
MSI A78M-E35
AMD athlon x4 760k
R7 260x 2GB OC
corsair cx430
My 260X at 1150MHz never goes above 70 degrees Celsius while playing games, something must be really wrong, I hope you figure it out.
Mobo MSI X370 Carbon CPU Ryzen 7 1700 3.8GHz RAM Corsair Vengeance RGB 2x8GB 3000MHz GPU ASUS GTX 1070 Strix Case NZXT S340 Storage Samsung 960 EVO 250GB M.2 - Seagate 1TB  PSU EVGA 750W Cooling NZXT Kraken X52 OS WIndows 10 Pro
Keyboard Arachnid Recore - Cherry MX Red Mouse Corsair M45  !!--GTA V--!!
My system with far more powerful hardware only consumes 200w at load. The CX430 is perfectly fine for that system.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
you need to figure out the temperature issue mate, going that high is a worrying sign.
have you checked if the GPU fans are spinning, they can fail / be programmed to not spin up enough.
have you tried putting the GPU into the brothers pc if his is running fine.
it would seem odd to have two defective GPU's in a row too..
tried another PCI-e slot if available?
