Does anyone know how to fix this problem with icons? i have just install razer synapse, after installing  it it become the icons like this, i did many things and i deleted the iconcache, but same problem! , sorry i forgot to upload the picture but its crashed,
but its exactly same this link
http://www.google.ae/imgres?imgurl=http://i.stack.imgur.com/Uka7D.png&imgrefurl=http://superuser.com/questions/167028/how-do-i-restore-shortcut-icon-images-in-windows-7&h=116&w=324&tbnid=MEnOs9OLrfiBiM:&docid=rGw99es-V0Us4M&ei=j1a3Vc-8Fe-p7Ab01KiADg&tbm=isch&ved=0CCoQMygQMBBqFQoTCI_As6TM_cYCFe8U2woddCoK4A
im using windows 7 ultimate 64 bit
https://linustechtips.com/topic/417133-icon-problem/
Revert to a restore point before installing razer synapse?
I had this issue not long ago, but cant remember what I did to fix it...
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
https://linustechtips.com/topic/417133-icon-problem/#findComment-5609695
You should usally be able to right click on the icon and choose preferences and the go to customize and find a button that says Change icon. Press that one and try to find the right otherwise just download it and apply the downloaded image. (The pathway names may not be right since I dont use english windows so I just translated the paths from the swedish verision)
FX-8350 GTX760 16GB RAM 250GB SSD + 1TB HDD
"How many roads must a man walk down?" "42"
https://linustechtips.com/topic/417133-icon-problem/#findComment-5609705
1. Press Ctrl-Shift-Escape to get the task manager.
2. In the Processes tab, click on explorer.exe and click End Process. You'll get a confirmation dialog. Click "End Process" to confirm.
3. From the File menu (still in the task manager), choose New Task (Run...).
4. Copy/paste/enter the following command in the run box:
cmd /c del %userprofile%\AppData\Local\IconCache.db /a
5. Open the Run box again with File --> New Task (Run...). This time, enter this command:
explorer.exe
6. All should be okay now. Open the Start Menu and confirm that your icons are fixed now.
Gaming/Folding rig: Coolermaster CM 690 II Advanced White | MSI Z77A-G43 | Intel Core i7 3770k @ 4.4GHz | 10GB G.Skill RAM | Nvidia GeForce GTX 780 | Samsung 840 Pro 128GB | Seagate 2TB | Seagate 2TB | WD Blue 640GB | Cogage Arrow (Passive) | Thermaltake Toughpower XT 675w | Windows 10 Pro
Photography
https://linustechtips.com/topic/417133-icon-problem/#findComment-5609712
I dont know exactly for win 7 but in windows 8.1 you can right click the icon/program on desktop and tick "properties". Then you cam tick change icon and you can chqnge tge symbol manual. Thats not a solution for the whole problem but you can change the icons for the most important shortcuts. Sorry for the bad english, but i'm german.
Comnacobra
https://linustechtips.com/topic/417133-icon-problem/#findComment-5609726
