I wanna buy the lenove U41-70.
It's using NAVIDIA GeForce GT920M 2GB card, 8 GB ram.  and a i5 core.
Will it be too hot that I need to buy a new cooling fan or it's ok?
If yes which type of air cooling should I choose?(plz be a lower price :rolleyes: )
How about after installing a new 16GB ram?
Thanks alot!
https://linustechtips.com/topic/417113-will-it-be-enough/
What are you going to be using it for?
It should be fine for thermals, its normally only gaming laptops that suffer bad thermals
https://linustechtips.com/topic/417113-will-it-be-enough/#findComment-5609442
Uhm, isn't that ultrabook or something like that? If it would be normal business style thinkpad, you could change CPU/chipset cooling but only to same model. Laptops are very specific to what fits. Anyway, doing that would definitely void your warranty. And adding ram doesn't do anything to any cooling. Not on desktop and definitely not on laptop.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/417113-will-it-be-enough/#findComment-5611614
