Hey,
I was wondering how you connect more then one PWM fan to your motherboard.
I have a Asus Z87-Pro. It has 6 4-pin fan slots, but only the CPU connecter supports PWM mode.
But I would like to connect my PWM fans to the motherboard on such a way that they aren't volt regulated, but that they actually that advantage of the fact tbat they are PWM fans. I know of the existence of PWM splitters. But I keep on wondering: when I connect one of those to the CPU fan connecter on the motherboard,and then connect all of my fans to it, won't it treat all my fans like it is the CPU fan?
https://linustechtips.com/topic/417084-pwm-fans/
yep. they'll all recieve the same PWM signal. My advice would be to get some kind of independently controlled fan hub that uses PWM, probably mountes in a 5.25 inch bay at the front of the case. I've seen a few around.
your mobo should have more than just one PWM controlled hub. If it's got 4 pins it's PWM controlled
PWM fan controllers cost a fortune.
PEWDIEPIE DONT CROSS THAT BRIDGE
https://linustechtips.com/topic/417084-pwm-fans/#findComment-5609090
no they dont
they are controlled by various temperature sensors on the motherboard
you can change the fan headers from DC to PWM control in the UEFI
and you can control the fan curve and what temperatures they respond to with fan xpert 2
https://linustechtips.com/topic/417084-pwm-fans/#findComment-5609112
my case comes with: http://www.phanteks.com/PH-PWHUB.html
and the mobo has 2 PWM connecters( the other 4 pins are volt regualted): the CPU and the CPU OPT. Can I connect the fan hub with the CPU opt and then connect my fans to this fan hub. But the fan hub is 3 pin though.
https://linustechtips.com/topic/417084-pwm-fans/#findComment-5609126
no they dont
So although they are set as voltage regulated, I could change that in the bios to PWM regulated? or am I misunderstanding you?
https://linustechtips.com/topic/417084-pwm-fans/#findComment-5609139
im not sure about your UEFI since its older but mine has a 'q-fan' tab at the top that takes me to fan control and there I can switch between DC or PWM
look for something like that in yours
and why do you need PWM anyway? why do you want your fans to run at 20%?
https://linustechtips.com/topic/417084-pwm-fans/#findComment-5609152
Well I upgraded my case. I wanted other fans because of esthetical reasons and because of the noise level. My brother still owned me a birthday gift so he wanted to pay them for me.
I gave him a link, but he ofcourse bought  PWM's. But now i have them, why not try and take advantage of them, or atleast that was my thought pattern. I'll look into the Q-fan thingy this a little later then. thanks for the tip.
edit: according to my manual it should be in there
http://imgur.com/q3RiHXq
https://linustechtips.com/topic/417084-pwm-fans/#findComment-5609199
Hey,
If your other headers don't support PWM, you can use splitters, but you'll need to find out How many amps the specific header can output. Then you need to calculate how many of your fans add up to that amount minus 10-20% for safety, never want to try and draw the absolute max off it.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/417084-pwm-fans/#findComment-5609241
if they all come off of one header, they will all get the same PWM signal. That was the context
why would he plug all of the fans into a single header when there are plenty on the motherboard
https://linustechtips.com/topic/417084-pwm-fans/#findComment-5609340
I can't chose between DC or PWM, just disable and enable ;(
https://linustechtips.com/topic/417084-pwm-fans/#findComment-5609478
hmmm
and there are no other settings in the UEFI to enable PWM?
have you tried connecting your fans to the headers anyway to see if they go below 40% with fan xpert?
there might be a setting in fan xpert 2 to enable PWM
idk because i use thermal radar, not fan xpert
https://linustechtips.com/topic/417084-pwm-fans/#findComment-5609576
hmmm
I can't find any, I can enable and disable PWM for my CPu fan but not the rest and i'll look into the fan xpert 2 thingy :)
Edit: I don't seem to have fan xpert 2 ... :/
https://linustechtips.com/topic/417084-pwm-fans/#findComment-5609947
