For my new gaming build I'm looking at a few psu choices. Not sure if 450 watts is enough for a i3 4160 and a r9 280. So I have the seasonic 520w 80+ certified fully modular power supply. And the seasonic 450w 80+ gold certified modular psu. The are the same price. Which should I get
https://linustechtips.com/topic/417039-psu-help/
No harm in getting the 520W. Allows for more upgrade headroom and both are good PSUs.
https://linustechtips.com/topic/417039-psu-help/#findComment-5608618
And 80+ bronze vs 80+ gold. You would still go for the extra power?
Gold rating doesn't help with overclocking or anything. Unless you really need those couple of dollars you will save from the slighty reduced power draw, it's better to give your computer more wattage headroom.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/417039-psu-help/#findComment-5608646
Yep. You won't be able to tell the efficiency difference with power draw like yours (nearly none)
https://linustechtips.com/topic/417039-psu-help/#findComment-5608652
