I would recommend you the r7 360. It will do very well, and while I have never really had a Intel beneath an i3, I am pretty sure there will be no bottlenecks. So, suggesting sapphire r7 360.
BTW, for power, it has a single six-pin power connector, so, you should be clear...
750 ti would probably work but it is more pricy In my case... Go with the r7 360 from sapphire. Either atx or it's will probably be fine.
