My radiator is way too dusty and dirty to the point to where it's affecting cpu performance. I was going to take it outside and just spray it with compressed air but apparently I heard that it wouldn't work. Is that true? If so what's the other way of cleaning it?
Taran should run for president!
https://linustechtips.com/topic/416103-cleaning-h100i-rad/
Vacuum works well. Disconnect the whole rad/pump assembly from the PC first, though.
Wait really? I could use a vacuum? The thought passed my mind but I thought static build up would affect the rad too! Thanks I was running low on compressed air xD
https://linustechtips.com/topic/416103-cleaning-h100i-rad/#findComment-5596628
