Cpu temps to high...
Solved by LogicalDrm,
No, your thermal paste hasn't moved away. It may have spread bit more than it was, but that doesn't have any significant effect. Unless you already had too little of it. And the way 212 Evos mounting hardware is designed, it has bolt in the middle of crossed bracket. That works bit like scissors and allows using multiple sockets with single bracket. Downside is slight twisting if turned.
As for temps. It might be that bot fans are running bit slower than what single fan was running. While this doesn't have huge effect on temps, it might bump them just bit so you (being somewhat new to cooling) will be scared of them.
