System shuts down abruptly at random
Solved by TwOne,
I decided to take the PC outside and blew it out with an air compressor. I made sure to blow the CPU heatsink out from all angles (a lot of dust flew out). When I was done I hooked up the system and these were the temps I'm getting (ambient temp is slightly above 20C/68F):
CPU:
idle on Desktop: 34-39C (93-102F)
under load (max temps): 55-60C (131-140F)
GPU:
idle on Desktop: 24C (75F)
under load: 50C (122F)
