its a bus gpus ride to the store/your house.
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/415792-help-me-figure-this-out/#findComment-5592775
Don't even worry about it CJ, it doesn't really matter.
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/415792-help-me-figure-this-out/#findComment-5592823
Sure?
Well it does, but on that card it's fine.
https://linustechtips.com/topic/415792-help-me-figure-this-out/#findComment-5592880
The GPU Bus is the link between the GPU and the memory on the Graphics card. The lager the bus the faster the GPU can communicate with the memory, the GTX 960 only has a 128bit bus as opposed to the likes of the GTX 980s 256bit bus, but the GTX 960 has half as many cores, and is half the price.  The AMD Radeon R9 285 the nearest priced card i can see and you can compare with the GTX 960 it has a faster memory Bus but benchmarks show at stock speeds the GTX 960 is very similar and usually out performs it. I guess Nvidia designed the GTX 960 with a 128bit bus because thats all it needs ?
I have found the best way to choose a graphics card is to pick your budget and take a look at some relevant benchmarks to compare different cards. Then make your choice from there, you dont need to get into the technical jargon of bus speeds etc... its the simplest way !
1.21 gigawatts !!! 1.21 gigawatts!!.... Great Scott!
https://linustechtips.com/topic/415792-help-me-figure-this-out/#findComment-5593017
