Any program to control CPU fan?
Go to solution Solved by Firestorm,
Yes, pretty much. i use it on my laptop as the fan curve is a bit weird and i just pump the PWM percent to 100
    Name explains it all.. is there any program to control system fans within windows, INCLUDING cpu fan???
MOTHERBOARD: some Asus motherboard CPU: I3-4130 GPU: Gigabyte(?) GT-1030 RAM: 8GB G.SKILL SNIPER 1600MHZ RAM + 4GB AMD ram PSU: Corsair CX450 CASE: Corsair Spec-03 OS: Win 10 64 bit Keyboard: Logitech G510s Mouse: Corsair G300s Camera: Canon EOS Rebel T5
I like outdoor warning sirens. Ask me anything about them.
https://linustechtips.com/topic/415780-any-program-to-control-cpu-fan/
Ummm... You could try speedfan, but that doesn't work well for me at all. I'd just get like a cheap fan controller with dials or something.
Like this, [spoiler=]http://www.mwave.com.au/product/deepcool-black-rock-master-v30-multi-io-fan-controller-ab60231
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
     Well I  don't really have moneh for that stuff.. but thanks for the suggestion, I'll try speedfan.
SpeedFan works well for me
      How do I use it, just push the up arrows for the %'s of speeds, then blippitybloppitybloop, my fans are faster?
Dude they're like $20, mow a couple lawns.
        I'm not 18 and I don't have a job :/ I just got a 10$ server yesterday :/ (PowerEdge 2850)
Thx for the suggestion tho.
I'm 15 :|, I don't have a job either (mind you I'm looking for one).
         Err the fan speeds don't seem to be changing.. D:
     Quoting myself.. It does work.. just doesn't make a huge change, but all helps, thx!
