I was sent a link over skype by a contact. It was a twitter link however when hovering over the link it showed me a goo.gl link
I was being dumb and clicked this link. The link took me to a the website 'Womens Health Magazine" in the fitness section. As far as I can see in my chrome option nothing was downloaded or anything like that.
Am I at risk here? I can provide more information if requested thanks! :/
https://linustechtips.com/topic/415770-malicious-skype-link-help-please/
I was sent a link over skype by a contact. It was a twitter link however when hovering over the link it showed something similar to < //goo.gl/???? >
Please remove the like from your post. Could be something bad. Just scan your system using Malwerbytes.
Well, if you haven't noticed anything wrong there doesn't seem to be a problem. However, if you do, give me a yell.
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
I have been following this video -
I checked if any programs had access to skype and that came up empty which is a good sign however I found this in my appdata - http://gyazo.com/8d6eb1d559615d2468b35d11d1261220
What should I do with that chinese writing thing.
I'd just do some scans with like adwcleaner + ccleaner to be sure.
what is that chinese file doing there.
What?
Im going to reinstall skype and make a new account
righto, make sure to delete all of the folders associated with it to get a fully clean skype.
Somehow my skype account has premium so I think i will just delete everything that has to do with skype, reinstall, do a virus sweep, and then delete all my contacts and start fresh. Does it sound like a safe plan?
Yup.
