Bulk Storage Help
Solved by TheMcSame,
How would it double the chances?
More drives = higher chance a drive will fail. If you have 1 drive then only one drive can fail, if you have 2 then then there's two drives that can fail so there's a slightly higher chance that a drive will fail.
Anyway, I'd go for whatever provides the best price/GB which is likely a 2TB drive from Toshiba or HGST.
5
kasdashd ·
2
6
Ishikudeska ·
Posted in New Builds and Planning2 -
Xxu ·
Posted in Servers, NAS, and Home Lab1
play_circle_filled
Latest From ShortCircuit:
