i have a fairly good pc at the moment but the graphics card is very old and not upto the task of gaming like it used to (geforce xfx 7900gs 256mb ram)
the pc specs when i get the graphics card i want to get.
gigabyte ga-78lmt-usb3
8gb Kingston hyper-X blue 1600mhz ram (2 sticks of 4gb)
amd phenom ii x4 955 (using stock cooler)
1 normal ide dvd burner
GEFORCE EVGA GTX 660 TI -----------------------------THE UPGRADE CARD
wd black 1tb
1tb wd blue
1tb wd green
250gb seagate barracuda
 zalman z11 plus case including 4 fans
the power supply i have now is a corsair 500w psu..how many watts would you recommend i get ?
https://linustechtips.com/topic/41557-will-i-need-a-bigger-psu/
This is my Lightsaber.          {[=]////]"[¬'/\Y/#####################################
This is my other Lightsaber. (T!!!!!!!T=:"|[\#####################################  #killedmywife
https://linustechtips.com/topic/41557-will-i-need-a-bigger-psu/#findComment-539540
