How many Watts do i need?
Solved by BrinkGG,
Hey does anyone know what power supply i should get i have a
CPU: Intel Core i3-4160 Haswell Dual-Core 3.6GHz LGA 1150 54W
Motherboard: ASUS Z97-PRO GAMER LGA 1150
Video card: MSI R9 380 GAMING 4G Radeon R9 380
RAM: HyperX FURY Series 8GB (2x 4GB) DDR3 1866MHz
Storage: Western Digital Blue WD10EZEX 1TB 7200 RPM
I'm guessing i should get a 750W Power supply i just want to know if that is good or not
WAYYYYY TO HIGH!
450w to 550w is all you need. Since you can't oc the CPU, you probably don't need the Z97 mobo either.
