Its normal yeah My laptop is around 80 to 90 Because i work to hard :P
Tag me if you need me :D
Desktop:                                       Laptop:
CPU - i7-4790k                            CPU: I7 7700HQ
GPU - Inno3D 1080TI                  GPU: 1060
Mobo - Gigabyte Z97X-SLI          Memory: 16 GB
Memory - 32 GB DDR3                Storage: 1256GB
Storage - 11 TB
Phone: ONEPLUS 6 128GB
https://linustechtips.com/topic/415368-heat/#findComment-5587760
laptops are different when it comes to heat, becuase of how small their coolers are
OP, check if the CPU cooler is seated correctly and your thermal paste is not dry.
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/415368-heat/#findComment-5587785
My cooler is perfect en met thermal paste is not dry
I work so much on my laptop that its warming up My cpu is only 1.40 Ghz in quad Core
soon iam buying an new pc
Than i don't have this problem anymore
Specs of my new pc:
GPU: Dual Gtx 970 Gigabyte Winforce
CPU: Intel Core i7 4790k
CPU COOLER:Be quiet shadow rock 2
MOBO:  GIGABYTE GA-Z97X-SLI
RAM 16 GB kingston HyperX 1600 Mhz kit
CASE: Fractal Design Define R5
BOOT DRIVE: Samsung 850 Evo 120 GB
PSU: Cooler Master V750S
HEADPHONES: Razer Kraken Pro Neon Green
KEYBOARD MOUSE:  CM Storm Devastator
MICROPHONE: Blue snowball
Desktop:                                       Laptop:
Storage - 11 TB
https://linustechtips.com/topic/415368-heat/#findComment-5587864
Specs of my new pc:
but your sig says that that is your dream PC lol, I was talking to the person who posted the thread about the thermal paste and all
https://linustechtips.com/topic/415368-heat/#findComment-5588000
Yeah i know i need to edit my sig But thats the pc that iam gonna buy in august.
Desktop:                                       Laptop:
Storage - 11 TB
https://linustechtips.com/topic/415368-heat/#findComment-5588024
Specs of my new pc:
Why buy dual 970s?
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/415368-heat/#findComment-5588175
Why buy dual 970s?
Iam planing to go streaming and i want to play in suround And i need 3 Dvi ports Because my screens don't hava an hdmi/display port And i want enouch video memory for the future so that my games don't run in problem with that
Desktop:                                       Laptop:
Storage - 11 TB
https://linustechtips.com/topic/415368-heat/#findComment-5588373
But you will run into future games problems with only 3.5GB Vram what programs do you use for video editing and rendering?
        Setup
https://linustechtips.com/topic/415368-heat/#findComment-5588406
I only want to go streaming for more interaction with the viewers.
I don't like recording :P
I use Obs/Xsplit for livestreaming  And photoshop For photo editing and i use obs for recording to if i need to and edit it with sony vegas
And i play gta V with is already using 2048 GB But i only have an 1024 Gb ram GPU
Desktop:                                       Laptop:
Storage - 11 TB
https://linustechtips.com/topic/415368-heat/#findComment-5588460
