Best microphone for around $100 aud that i can connect to a pc and phone
YT2002
Hi. I am in need of a new microphone for around $100 ($100 to 130) that i can hook up to both my pc and phone. I dont want to buy any expensive adapters, so the at2020 i cant consider unless there are cheap adapters. Thanks
PC is Intel Core i5 6400, GIgabyte H170 Gaming 3, Corsair Vengeance LPX 2x4GB 2400Mhz ,Sandisk Ultra Plus 128GB, WD Blue 1TB, NZXT S340, ASUS Geforce GTX 960. Fractal Design Tesla R2 650W. http://au.pcpartpicker.com/p/793XNG. Graphics card choices don't always have to be dictated on performance. If you want the game stream and power consumption of the GTX 970 get that. If you want raw performance of the R9 390 get that. In the end we are all gamers, so what if your buddy gets an extra 5 fps?
i haven't heard of a microphone that could connect to a phone at all. Plus the phones don't uses HD audio due to incompatibility with older phones so i guess you should comprised the phone microphone and get a good microphone like the Blue yeti or the AT2020
I saw on cnet you could get a 3.5mm to xlr, Do you know any xlr microphones that dont require to much power?
