Of course not 100% silent
Edit: ATX Mid tower
Fractal Design R5 http://ca.pcpartpicker.com/part/fractal-design-case-fdcadefr5bk really high quality case.
Although just know for probably any case almost anywhere shipping and handling is going to be like $20 extra
https://linustechtips.com/topic/414843-best-budget-silent-case/#findComment-5581656
The define s is not silent optimized quite like the r 4 and r 5. It has sound dampening foam but its more for water cooling . If silence is what you want go for one of those. I have the r4 and its great!
https://linustechtips.com/topic/414843-best-budget-silent-case/#findComment-5582626
