so i found  a used amd 290x reference coller for 330usd, 300euros  but its the reference coller so i am not so sure about the prize what do you think people should i buy it
CPU:Intel I5 6700k (4.7GHz)  Mobo:Asus maximus viii hero RAM:HyperX 16GB  GPU:MSI gtx1080 Gaming X
Case:Fractal Design Define S SSD:Kingston 240GB HDD:1TB & 2TB raid 0 PSU:Corsair RMX750 Cooling:H100i v2 OS:Windows 10
Display:Benq GL2440,LG 29" Keyboard:Tesoro Durandal Mouse:Deathadder Sound:2.1 GENESIS NCS-0856, PC-37X, Razer manowar
https://linustechtips.com/topic/414623-290x-reference-cooler/
depends on how much you will use the card and your budget.
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
https://linustechtips.com/topic/414623-290x-reference-cooler/#findComment-5578708
