hello, im now trying to choose watercooling components for a z97 based system and ive tried to choose some parts. are there any recommendations of changing parts/ components to improve performance or decrease price? i just want to know if all of this will work. and i have a budget of $400
tl;dr: will the component lisk work to watercool a z97 cpu? (i7 4790k)
Other: Ek- Supremacy MX ($54.99)
Other: EK-XRES 100 DDC 3.2 PWM ($139.99)
Other: EK- Coolstream E 240 ($61.99)
Other: EK-Ekoolant EVO UV BLUE ($17.00)
Other: TUBE PrimoChill PrimoFlex ($24.39)
Other: EK-ACF Fitting x 7 ($45.43)
Total: $377.67
Generated by PCPartPicker 2015-07-24 14:13 EDT-0400
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/414581-help-in-choosing-watercooling-components/
Well that pump is a bit pricy, looks good but what about a GPU block?
amnerd  B) Linux enthusiast.
  • CPU: Intel i5 4690k @3.5ghz  Motherboard: MSI U3 Plus Z97 GPU: Radeon R9 270x 2gb OC HDD: WD Green 3tb SDDs: Samsung 120gb, Kingston V300 120gb Case: Fractal Design Define R5 PSU: Corsair V650 Fans: Corsair AF14 x4 CPU cooler: Hyper 212 EVO (Upgrading soon)
since i have a non reference gpu, i cant
and any other  pump/res combo you would recommend?
would this one also do the  job for much less?
Rigs I've Built
Yes, you can.  EK makes waterblocks for specific GPUs.
not for the 280x tri x though
and would a 240 rad cool both the cpu and gpu well?
Rigs I've Built
They make VGA universals, no full waterblocks.
can you recommend me any parts for a 280x tri x?
and would the 240mm rad cool both cpu and gpu well?
Rigs I've Built
That one looks good, probably better for your needs than that expensive res and pump :)
