If you have integrated HD, then plug your cable into the right port.
Otherwise, if you have a gpu, plug it into the right hdmi/vga port.
If that doesn't work, replug in your GPU into your pcie slot, as your power supply should be working because your fans are spinning.
https://linustechtips.com/topic/414522-help-me-please/#findComment-5577458
Is your ram all the way in ( happened to me, everything turned on but no screen, re seated the ram bam )
Do you have your display port, had I, VGA or whatever you are using plugged into the motherboard or the GPU?
If we had the specs to your PC it could help.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/414522-help-me-please/#findComment-5577480
yeah
https://linustechtips.com/topic/414522-help-me-please/#findComment-5577542
I have a picture now as i took out the graphics card and i'm using the intergrated graphics until i can get the drivers but my boot External HD isn't working now
I just took everything from the disk and put it on a usb hard drive but it says Reboot and select proper boot device even though it is selected and shows it's there ?
Why Is it windows 10 not 9?
because 7 ate 9
(say it)
https://linustechtips.com/topic/414522-help-me-please/#findComment-5577829
You can't boot your computer without an internal hard drive...
https://linustechtips.com/topic/414522-help-me-please/#findComment-5580381
