Led strips!
Thanks but I want a connector like this: http://www.allpinouts.org/images/6/67/Connector_mb_fan_3pin.jpg
Ok, firstly sorry for being a GOOF.
Now: If you can't find one then it easy to make one, all you need to do is: Get any bog-standard Blue 60cm LED strip (http://www.scan.co.uk/products/akasa-ak-ld02-05bl-vegas-led-strip-light-60cm-blue) cut off the connector, strip the wires and buy a 3 pin connector (http://www.ebay.co.uk/itm/5-Pcs-x-Shakmods-3-Pin-Female-Black-Fan-Power-Connector-15-Free-Pins-/171295817657) and connect the wires to that. Make sure you get the polarity correct or it won't work.
Bear in mind that fan connectors supply 12VDC or 5VDC so make sure your leds are OK for that, the linked LED's take 12VDC so make sure your motherboard outputs 12VDC rather than 5VDC if you are using that one.
If you're still confused, just ask. ![]()
