Reducing pc fan vibration
Gonna be doing this soon: -https://www.youtube.com/watch?v=BhkYrzST7V4-
And now I need a solution for my hard drive and fans. Anyone know anything that would work well to stop fans from vibrating against the case?
Suspending the hard drives or mounting it to a sheet of plexi with thick foam or soft rubber feet basically negate all vibrations to the case:
http://www.silentpcreview.com/article8-page2.html
For something slightly easier, buying rubber washers from a hardware store works wonders.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
Rubber "screws". Don't get cheapest and select ones that are right for your fans. Like if your fans use closed screw holes, get long screws. For open, you and use both, short and long.
You can get washers/o-rings too but those are much weaker if you have super-rattly fans. Best would be something covering whole frame, not just screw holes, or mounts like ones on Noctua fans.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
