Well i hope this isn't a pointless thread but eh here it goes.
My PSU needs a little bit of a clean as it's a little dusty inside, can i just use a compressed air can? would be handy since im going to clean up my PC with a can anyhow.
Hey bro i like yo *vomits on you*
SpOOkY  - Intel Core i7 4820K - Sapphire Radeon HD 7970GHZ Toxic Edition 6GB - 16GB Corsair Vengeance 1600Mhz - Gigabyte X79-UD3 - EVGA Supernova G2 850W
My GrApHiCs DeSiGn TeAcHeR Is GoInG To bE sO MaD
https://linustechtips.com/topic/413299-cleaning-psu/
I used a compressed air tank.
those air cans tend to blow air and condensate if you do wrong.
https://linustechtips.com/topic/413299-cleaning-psu/#findComment-5561067
Don't use compressed air, I would think that can tear off capacitors. Just use a rag to get the surface stuff out and run the fan as fast as possible for a bit?
https://linustechtips.com/topic/413299-cleaning-psu/#findComment-5561070
Use compressed air to blast the dust out. Just hold the fan in place so that it doesn't spin.
I LOL'ed. There is no way caps will be blown off. They are soldered and glued in place.
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
https://linustechtips.com/topic/413299-cleaning-psu/#findComment-5561141
I LOL'ed. There is no way caps will be blow off. They are soldered and glued in place.
You've clearly never read through Experiences with Non-Techies....
https://linustechtips.com/topic/413299-cleaning-psu/#findComment-5561146
The amount of power stored in the capacitors is enough to shock or even kill you, even when unplugged. Be careful when talking the housing off.
Well i didnt really want to take the housing off of the unit anyhow :') since i didnt want to void my warranty and it does look more difficult to do on the G2's. and i can be fairly clumsy.
can i just then use compressed air from a distance perhaps if it's even too powerful?
https://linustechtips.com/topic/413299-cleaning-psu/#findComment-5561151
Just hold the fans.
Main PC: CPU Xeon E3-1231 V3 - MB Asrock B85M Pro3 - RAM 16GB Kingston - GPU GTX 1070 Gainward Phoenix - PSU Corsair AX760i - Monitor  LG 22EA63 - Keyboard Corsair Strafe - Mouse Logitech G402 - Storage 2x3TB WD Green - 240GB OCZ SSD
https://linustechtips.com/topic/413299-cleaning-psu/#findComment-5561170
I've clearly done that (cleaning w/ compressed air)for as long as I've had a PC. It will take some force to rip those caps off even if you do it by hand.
Just make sure to hold the fan in place with a stick or something so that it doesn't spin. When I clean my PSU I blast the vents at point blank.
60FPS Microwave
https://linustechtips.com/topic/413299-cleaning-psu/#findComment-5561186
Not all PSUs are held up to the same quality as others, and even ones that are known to be built solidly can have a manufacturing mishaps.
"Rawr XD"
https://linustechtips.com/topic/413299-cleaning-psu/#findComment-5561198
I've clearly done that (ccleaning w/ compressed air)for as long as I've had a PC. It will take some force to rip those caps off even if you do it by hand.
From what I remember some non-techie had some crazy air blaster thing that was set to high pressure and blew the caps off. I'm pretty certain it was on a motherboard, not a PSU, where the chance of blowing them off is much more likely, but it still holds legitimacy. Just don't be a dingus and you'll be good.
https://linustechtips.com/topic/413299-cleaning-psu/#findComment-5561209
It was a regular air compressor set to around 6.5 bar(94psi).
If you get up close like 2 inches away and you will have to as it's a PSU you are cleaning you will need to direct the air at the holes in the grill, the air pressure coming from a compressor is enough to rip the caps off, make sure to have a regulator and set it to about 15psi.
https://linustechtips.com/topic/413299-cleaning-psu/#findComment-5561241
