Im Going to be doing some painting but what is a good type to use on say a case?
Depends on the color and material your painting but as paint automotive paint give better color selection, and more vibrant/bright colors espically in white or deep blacks.
For techniques on painting and procedure I have a write up on that under the painting section:
http://linustechtips.com/main/topic/407754-modding-faq-common-mods/
https://linustechtips.com/topic/412560-painting-help/#findComment-5551930
Here is a good how to paint guide I found.
lol. and auto paints. dont paint cpu coolers or pcbs. shields should be good and maybe gpu coolers on the outsides. why not just get the right color case?
 Just because you don't care, doesn't mean other others don't. Don't be a self-centered asshole. -Thank You a PSA from the people who do not say random shit on the internet.
https://linustechtips.com/topic/412560-painting-help/#findComment-5551931
