Help with water cooling kit
Go to solution Solved by W-L,
Ah, forgot! I plan to buy an extra 240mm rad and one 120mm :)
That'll give pretty good cooling, one thing with that kit however if your budget and space allows for it I'd suggest to get the kit with the Photon pump combo unit those are usually better than the bay reservoir especially for filling and bleeding the loop.
And of course you'll need two GTX780 waterblocks to add into the loop.
Greetings!
I want to coooolllll my system and looking for optimal brand.
What about XSPC RayStorm D5 EX280 WaterCooling Kit? Can it handle Gigabyte GTX780 SLI  and Core i5-4690K?
While possible it will give less than ideal temps, it's recommend to have atleast one 120mm rad space per component and more for silent cooling. Something that has a 480mm rad space or adding another rad into the loop would be a good option.
Oh, thank you for advice, I'll think about it... Hm, and this tube looks very cool, with red colorant....
yeah, I've already found waterblocks, I think - Razor GTX Titan / 780 / 780Ti V2.
If you want to go with colored coolants and clear tubing I'd suggest Mayhem's Pastel or x1 lineup they're pretty top notch.
