Question recading ASIC quality.
By
don_svetlio
in Graphics Cards
in Graphics Cards
Solved by Raudi_,
Only thing you need to know about asic is the higher the ASIC reading is the lower the overall powerdraw of the card will be on air, as it will have less voltage leak. Otherwise its 100% redundant for anything else.
thrasher_565 ·
Posted in Hot Deals0 -
5
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
8
derekchan ·
Posted in New Builds and Planning12 -
1
2
7
5
7
play_circle_filled
Latest From ShortCircuit:
