Screen problem
Go to solution Solved by wangyuji431,
I have put a picture could you please look at it and tell me what you think?
This could be a monitor problem, which happens when the cables (VGA)? Start to loosen or break. If you have a VGA cable, or anything with physical connections, look at your pins on it, and see if anything is bent. If it is an hdmi cable, see if the screen changes when you bend specific portions of the cable, although this rarely occurs. Moreover, you can look inside your graphics card connector, and see if anything is left in the socket, such as broken pins.
This looks to me like your monitor is having trouble refreshing the display, or is overheating. Try to see if the monitor has lots of dust in it, or simply hook up another monitor, in order to diagnose the problem. To check if this is the case, set your refresh rate down to 20 or 30 hz and see if that affects the timing of the monitor splitting.
My screen splits in two while playing. I fix it with a restart but it is annoying. Can someone help me? I should note that my monitor is 7-8 years old.
CPU: AMD Phenom II X4 B50 3.2 GHz // GPU: VTX Radeon HD 6670 1GB DDR3 // MB: Asus M4A88T-M // RAM: 2×2GB DDR3 // PSU: MS PRO 550W ATX P4 // Monitor: Samsung 1280×1024 resolution // Windows 10 64 bit // Mobile: LG G3 32 GB
https://linustechtips.com/topic/411723-screen-problem/
I like potatoes.
CPU: Intel Core i5 4460 3.2 Ghz \\ Motherboard: MSI H97 PC MATE ATX \\ RAM: Corsair 2x4 GB 1600 Mhz \\ GPU: Asus Strix GTX 970 4 GB DDR5 \\ Storage: WD Caviar Blue 1 TB, 7200 RPM and an external WD Elements 1 TB HDD \\ PSU: Corsair VS650W \\ Case: Cooler Master K350 \\ Optical drive: Samsung R/W 24x \\ OS: Windows 10 64-bit \\ Keyboard/Mouse: Both DELL \\ Display: Samsung 28-inch TV 1080p 60 Hz \\ Phone: Samsung Galaxy S5 Electric Blue 16 GB
https://linustechtips.com/topic/411723-screen-problem/#findComment-5541673
Here is a picture of itpost-246419-0-04258500-1437429831_thumb.
https://linustechtips.com/topic/411723-screen-problem/#findComment-5541774
What type of split? If it has a windows taskbar on each side, it is due to either virtual displays getting messed up in your display drivers, a faulty display, or even a faulty graphics card (extremely unlikely).
https://linustechtips.com/topic/411723-screen-problem/#findComment-5554586
https://linustechtips.com/topic/411723-screen-problem/#findComment-5558411
Also, it could just be your old, failing monitor. Try using the monitor's auto readjust button, or reinstall the monitor drivers. Also, this may be your VRMs overheating in your graphics card, or your memory overheating. Put the graphics card memory clocks down to default, etc.
Next, go into your bios, and wave your cursor around and change the tabs on it for ten minutes. If the monitor is faulty, then the screen will split while inside the bios. If not, boot into safe mode, and see if that resolves your issue.
https://linustechtips.com/topic/411723-screen-problem/#findComment-5558455
Wow man thanks you're a great help. I'll try this things if nothing works it is probably bcos my monitor is very old.
https://linustechtips.com/topic/411723-screen-problem/#findComment-5559894
