Hey,
This may be awkward to ask for or may make me seem as lazy or declare me a noob, but can someone come up with a build for me please? I wanted to buy everything off of amazon germany, cause I live here.
So yea my birthday is coming and I asked for a gaming pc and I guess the best option is to build one. Im a total noob at building pc's, cause this is my first own build in my life. I want to have a 980 preferably in my build, because the 970 has a vram issue.
I think this is difficult to do but having a 980 in a 1500 euro budget is possible or?
I dont need peripherals cause I got them already, ram I dont need either cause they were on sale quite cheap.
Would be nice if the pc can have a black/red theme with LEDs
I started selecting some components already on pcpartpicker such as the cpu, cooling method, the operating system, and storage. I will use the SSD from my mac though because I wont be using it a lot after I get my pc  :P .
Quick question: Is there a big difference in 1080p gaming and 1440p, are you able to see the difference?
Would be awesome if someone helped me!
Thanks
                                         Cold
https://linustechtips.com/topic/411647-first-build/
Yes obviously you can see the difference between 1080p and 1440p gaming. If you are looking for something in between the 980 and the 970 that can do 1440p gaming go for the r9 390x.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/411647-first-build/#findComment-5540797
Hey,
If you cannot tell a big difference between a 60HZ monitor and a 120HZ monitor then no, unless you have a sharp eyes that can identify the differences between 1080P and 1440P. However, 1440P might give you a little bit sharp images over 1080P. As for 970 VRAM issue is a lie, it does actually have 4GB VRAM but NVIDIA split 3.5GB as high speed were 0.5GB as a slow speed.
https://linustechtips.com/topic/411647-first-build/#findComment-5540819
That is the VRAM issue though
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/411647-first-build/#findComment-5540898
I would go for a 390X if you want to play 1440p
        Setup
https://linustechtips.com/topic/411647-first-build/#findComment-5540901
1440p all the way. you'll need a good monitor though. 1ms is great.
are you planning on overclocking the cpu and gpu?
1080p is still good if you have 144 hertz and 1ms
Yea Im planning to overclock both. I have an old monitor that I am using right now as an extension display to my current comp, its very old though. Here it is: Monitor. I wanted to buy a 1440p or 1080p monitor now, and sometime next year ill probably sell the old monitor and buy an additional 1080 or 1440p. Dont really know if 1440p is worth it though and will meet my budget.
                                         Cold
https://linustechtips.com/topic/411647-first-build/#findComment-5540933
You mean 3.5GB VRAM issue? If you do the math 3.5GB + 0.5MB = 4GB, but if you mean performance issue then yes your performance will drop once you exceed 3.5GB high speed VRAM.
It's a VRAM issue but you are right that the 3.5GB issue is false but it's still a VRAM issue that will cause stutters and performance drops when you get to the slow VRAM
        Setup
https://linustechtips.com/topic/411647-first-build/#findComment-5540984
Is that what you picket out in your pcpp included in 1500€ range or not (ram,ssd and windows)
CPU: i7 5820K Motherboard: MSI x99A SLI PLUS RAM: Corsair Vengeance DDR4 2800mHz (4x4gb) GPU: MSI GeForce  GTX 980Ti Case: NZXT S340 Storage: 840 Evo 120gb and WD Blue 1TB  PSU: EVGA SuperNOVA G2 850W CPU Cooler: be quiet! Dark Rock 3
GTX 980 Ti (reference card) High Idle temps solution -
https://linustechtips.com/topic/411647-first-build/#findComment-5540986
No No I bought that stuff already, so its out of my budget. Budget is still 1500 euro.
                                         Cold
https://linustechtips.com/topic/411647-first-build/#findComment-5541028
Here is my configuration, hope you like it. NZXT s340 costs around 85€ or you can switch it with NZXT H440 (red and black version), and I have no idea how much is a SSD, but it doesn't matter since you have allready purchased it. I've also included 2 Corsairs AF140 with red LED lights. If you don't like led lights you can switch it with Corsair AF140 with red rings around the fan. For the AIO Cpu cooler, thouse stock fan on the radiator are ugly. Buy 2 more Corsair SP120 fans for that and you'll be fine.
http://de.pcpartpicker.com/p/vTmkZL
Hope it helps. Just play around try different combinations and send it here, so we can debate about it.
https://linustechtips.com/topic/411647-first-build/#findComment-5541090
Oh you can do so much more then. :D
https://linustechtips.com/topic/411647-first-build/#findComment-5541110
Change PSU for this one, and it's not too bad.
http://de.pcpartpicker.com/part/seasonic-power-supply-s12ii620bronze
https://linustechtips.com/topic/411647-first-build/#findComment-5541129
would this psu work as well.
http://www.amazon.de/Corsair-600Watt-Modular-Bronze-Netzteil/dp/B00ALYORPO/ref=sr_1_1?ie=UTF8&qid=1437424878&sr=8-1&keywords=600w+corsair
                                         Cold
https://linustechtips.com/topic/411647-first-build/#findComment-5541149
Just found this on tomshardware....
Konane said:
i have never done SLI before but i have heard nothing but bad things from it and most games don't support sli its what i hear atleast
Any modern game that has a decent GPU requirement will run fine on an SLI rig.
A single GTX980 is only 10-13% faster than a single GTX970 but its costs 60%+ MORE. That makes the GTX970 a MUCH better buy for the performance, if you need more performance, a second GTX970 is worth it.
                                         Cold
https://linustechtips.com/topic/411647-first-build/#findComment-5541172
Why less watts? It's better to have more watt power, then less. 750W will give you a lot of room for overclocking. And try to look for gold or better psus, just because you get better output.
I'll play around and paste a new link.
https://linustechtips.com/topic/411647-first-build/#findComment-5541214
GOOD GOD.
It doesn't mean it's a bad graphics card. I use my GTX 970 for 1440p Ultra settings and I get 60 fps no problem. I don't use AA because it's too much of a resource hog, and you don't need it so much as the resolution increases. Sure, using AA would mean using more VRAM, but then you get lower framerates because the GPU can't drive it, so saying, "I MUST HAVE 4GB FULL SPEED ON THE 970" is kind of a moot argument.
The GTX 970 is an excellent card, it sips power and stays cool. I can (almost) guarantee you won't be disappointed.
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
https://linustechtips.com/topic/411647-first-build/#findComment-5541337
Here is a similar setup, just a better motherboard (you could go with MSI gaming 5) the only difference is that gaming 7 has better cooling on mobo and so you can OC it a bit more. Fractal design r5 is best case you can find. IMO
http://de.pcpartpicker.com/p/v4Ygf7
https://linustechtips.com/topic/411647-first-build/#findComment-5541382
