This is my planned gaming PC build:
http://pcpartpicker.com/p/RYyfLk
Can you guys please look at it and tell me if the Cooler Master VSM 650W 80+ Gold Certified Semi-Modular ATX Power Supply is good enough?
CPU: i5 4690 GPU: Powercolor R9 390 RAM: 2X4GB DDR3-1600 G.Skill Ripjaws X Case: NZXT S340 Motherboard: Gigabyte GA-H97-D3H CPU Cooler: Some cooler I took off of an old Socket 775 Mobo
https://linustechtips.com/topic/411101-need-help-choosing-a-psu/
You might want more like 700-800 if you plan to upgrade a lot. If you don't plan to upgrade, 650 will be just fine.
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
https://linustechtips.com/topic/411101-need-help-choosing-a-psu/#findComment-5533931
That PSU is good but why not go intel?
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/411101-need-help-choosing-a-psu/#findComment-5533938
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=383
It seems on paper to be a really good PSU :).
(just the one reviewed here is a higher wattage one but there really shouldnt be much difference apart from that).
and i believe Linus has Cooler Master V PSU's in his editing Rigs :D.
Hey bro i like yo *vomits on you*
SpOOkY  - Intel Core i7 4820K - Sapphire Radeon HD 7970GHZ Toxic Edition 6GB - 16GB Corsair Vengeance 1600Mhz - Gigabyte X79-UD3 - EVGA Supernova G2 850W
My GrApHiCs DeSiGn TeAcHeR Is GoInG To bE sO MaD
https://linustechtips.com/topic/411101-need-help-choosing-a-psu/#findComment-5533997
yup they do
https://linustechtips.com/topic/411101-need-help-choosing-a-psu/#findComment-5534032
That's a good PSU but you should definitely get an Intel CPU....
https://linustechtips.com/topic/411101-need-help-choosing-a-psu/#findComment-5534048
yup they do
https://youtu.be/w0HZAkgCZv8?t=3m20s
yeah that's proof right there xD
https://linustechtips.com/topic/411101-need-help-choosing-a-psu/#findComment-5534054
You're going to be bottlenecking in all but a small number of games that support multi-threaded CPUs well. Definitely go with an i5 instead.
Explanation: http://linustechtips.com/main/topic/401217-more-updated-fx-vs-intel-for-gaming/
Yes, and for that price it's a great deal
"Rawr XD"
https://linustechtips.com/topic/411101-need-help-choosing-a-psu/#findComment-5535375
Is there a good intel processor for around the same price point that you know of?
https://linustechtips.com/topic/411101-need-help-choosing-a-psu/#findComment-5537736
I'm planning on playing games like battlefield 4, other FPS games, and the new battlefront coming out this November as well as some more easy to run games (CS:GO, Minecraft, etc.). Is the build good enough for that?
https://linustechtips.com/topic/411101-need-help-choosing-a-psu/#findComment-5537765
BF4 and newer AAA titles will be okay but there will still be bottlenecking. CS:GO and Minecraft will rape the FX.
This is better for cheaper
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($176.95 @ SuperBiiz)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($69.89 @ OutletPC)
Video Card: PowerColor Radeon R9 290 4GB PCS+ Video Card  ($262.98 @ Newegg)
Total: $698.29
Generated by PCPartPicker 2015-07-20 12:22 EDT-0400
"Rawr XD"
https://linustechtips.com/topic/411101-need-help-choosing-a-psu/#findComment-5539174
Total: $698.29
Do you trust PowerColor?
https://linustechtips.com/topic/411101-need-help-choosing-a-psu/#findComment-5542753
I've never heard of any issues with it. If anything it's more reliable then the one you had picked, I've had nothing but problems with XFX graphics cards.
I actually found out that the cheaper r9 290 I was considering is not the pcs+ version. Do you know if the card is still good?
https://linustechtips.com/topic/411101-need-help-choosing-a-psu/#findComment-5552990
Which one?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131668&cm_re=r9_290-_-14-131-668-_-Product
Should I use the Gigabyte Windforce version instead?
https://linustechtips.com/topic/411101-need-help-choosing-a-psu/#findComment-5553425
I personally prefer MSI Lighting R9 290X because temperature only reach 71C plus low noise. Here is the video of Linus testing all non reference R9 290X, but if you are going to choose Gigabyte Windforce version, well good luck with 83C max load.
https://linustechtips.com/topic/411101-need-help-choosing-a-psu/#findComment-5553466
Get that one (PCS)
Are there any problems with the xfx card? Apparently the powercolor card has a few problems.
https://linustechtips.com/topic/411101-need-help-choosing-a-psu/#findComment-5557209
I've had 2 PowerColor cards with no issues, but nothing but problems with XFX cards O.o
Have you used a PowerColor r9 290 though?
https://linustechtips.com/topic/411101-need-help-choosing-a-psu/#findComment-5560362
