Do I need Thermal Paste?
Hi. I have an i5 4690k, and it came with a stock cooler. The stock cooler already had thermal paste on it, and when I took the cooler off there's still most of it stuck on the CPU. I just got an AIO Raijinek Triton cooler, and I'm not sure if it came with the paste. If it didn't, do I need to add more, or will the dry part of it from the stock cooler work? If it does come with it, do I need to add more? Or should I scrape off the stock cooler paste off the CPU, then apply Raijintek's kind?
70% or higher isopropyl alcohol. Wet a lint free cloth, a microfiber cloth or a coffee filter will work fine. Clean both the CPU and the waterblock until there is no residue, wait a minute for it to dry, apply thermal paste, an amount between an uncooked and a cooked grain of rice. If it came with a tube of thermal paste use that, if not, you will have to buy some, zalman STG2, MX-4, MX-2, noctua NT-H1, PK-1, IC diamond, arctic silver 5, Cooler master Thermalfusion 400, any of those, i use STG2, but get whatever it's available at a decent price, just don't get generic stuff.
