Will I be bottlenecked?
Go to solution Solved by PineappleHolidays,
A little bit.
But don't worry about it
Yes a bit.
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/410979-will-i-be-bottlenecked/#findComment-5532811
