Hi everyone,
I just completed my first build with the Define R5 (Blackout Edition) and noticed that the front panel LED is blinking between blue and white.
I followed the user manual in setting up the front panel display connections on the motherboard so I am almost certain it's not something to do with the connections.
I've tried to find if this is normal or an actual issue but came up empty. I know the led is supposed to be blue so maybe the blinking means there's network activity? I am not sure.
If anyone has any ideas if this is normal or not I would appreciate it.
Thanks!
https://linustechtips.com/topic/410812-define-r5-blinking-led/
Which led is it? Can you post a pic?
LIBERATOR: Core i5 6400 @ 2.7GHz | GeForce GTX 670 2 GB | HyperX Fury 8GB DDR4 @ 2133 MHz | 250 GB Samsung 850 Evo SSD
My new build; Liberator, Check it out
The more friendly we are, the more helpful we are!
MY OLD BUILD (AKA PREBUILT MONSTROSITY)
INSANITY: AMD Athlon II X2 @ 3.0 GHz | Geforce GT 720 2 GB | 4 GB DDR3 @ 1333 MHz | 120 GB Silicon Power SSD | 500 GB Hitachi HDD
https://linustechtips.com/topic/410812-define-r5-blinking-led/#findComment-5530827
Unless I'm very much mistaken the only inputs for the LEDs on an R5 are power and HDD activity.  The Blinking is probably the latter, but even then it does surprise me that it's white.
Unplug one of the HDD led pins on the motherboard and see if the blinking stops.
https://linustechtips.com/topic/410812-define-r5-blinking-led/#findComment-5530935
Hi everyone,
Thanks!
Maybe you connected it to HDD activity light header on the mobo? Not sure why they would include 2 colors power led :/
Post a pic.
01111001 01101111 01110101 00100000 01101010 01110101 01110011 01110100 00100000 01110111 01100001 01110011 01110100 01100101 01100100 00100000 01111001 01101111 01110101 01110010 00100000 01110100 01101001 01101101 01100101 00100000 01100011 01101111 01101110 01110110 01100101 01110010 01110100 01101001 01101110 01100111 00100000 01110100 01101000 01101001 01110011
https://linustechtips.com/topic/410812-define-r5-blinking-led/#findComment-5530945
It was the power switch led that was blinking. Looks like the connector labels are wrong because by plugging in what is labeled as the HDD LED connector to the Power LED pins outlined in the manual, the light is now a constant blue. Though if I plug in the Power LED connectors to the HDD LED pins, there's blinking again... though more blue than white. Looks like I will be keeping the wrongly labeled HDD LED connectors unplugged.
What other light is supposed to blink with the HDD LED? Seems like both connectors are tied to the power switch led light.
post-221808-0-00625700-1437353118_thumb.
post-221808-0-43709300-1437353106_thumb.
https://linustechtips.com/topic/410812-define-r5-blinking-led/#findComment-5534614
